52047
Masking for Galvanising process
May 6, 2009
Dear sir ,
we are a leading transformer manufacturer in asia , we are sending
transformers for zinc coating .
During this process How to mask unwanted area like threaded
portions.
presently we are doing tapping for threaded portions.
regards
V.V. Satyanarayana
employee - Hyderabad
May 6, 2009
Hi, VV. You say you send these out for galvanising, and you also
say you send them out for zinc coating. Sorry to be a nitpicker, but
it makes a huge difference whether you want to mask these areas
against hot dip galvanizing (immersion in molten zinc) or against
zinc plating (immersion in an aqueous-based, ambient temperature. But
the easiest answer may be that most zinc applicators are capable of
masking, and would greatly prefer doing it themselves than to having
split responsibility for parts masked by others. Good luck.
finishing.com
Brick, New Jersey
August 13, 2009
1. How to mask the unwanted areas like threaded
portion/holes&studs during Hot dip galvanizing process.
2. How to Buff the surface for better look ( After Hot dip
galvanizing)
V.V. Satyanarayana
employee - Hyderabad, INDIA
