We want to switch to infrared curing on powder coatingApril 30, 2009 Dear reader, Giulianno Sperotto
May 7, 2009 I am not going to give you the answers you require... only some good advice. Without visiting your premises no one can/should give you advice on the locating of the heat source, their number or energy required. As you state the geometry of the items makes it an almost impossible task. In the long term you will save money by obtaining the advice from a company who can visit you and see what problems need to be overcome, i.e. shaded areas etc.
May 8, 2009 I do understand why you can't give a response to the letter
(reading it now, seems I gave to much information, and the tone seems
to ask for a precise response...), though my actual interest is in
obtaining some ESTIMATES from people who already use IR ovens. The
person who is providing a consultant job for us, is also a
representative of the company who wishes to sell the quartz lamps for
us, so i'm just trying to check what he is telling us. Giulianno Sperotto
First of two simultaneous responses -- May 12, 2009 PM's are more involved(time/cost)with IR's. Make sure and ask the rep to explain preventative maintenance procedures with you because it takes a greater commitment to operate an IR. Powder blows off of the parts onto the reflective surface and then cures. They need to be chemically stripped and polished frequently to keep the IR functioning at full potential. The way that you find out the the reflective surfaces are dirty is when a whole days worth of parts come out under-cured.
Second of two simultaneous responses -- May 12, 2009 Hi, tried to contact you direct via your email address and fax number without success. If you require assistace please contact me direct.
May 14, 2009 That's strange, as for fax maybe it was required that you called
and asked for fax signal first, or maybe one of the huge number
required to make an international call was missed... anyway, I'll
contact you, hope you can get back to me. Giulianno Sperotto
May 18, 2009 There are different designs so I can't really say unless I can see how the ceramic is being use. My main point was just check into the PM process of the unit that you buy. The IR that I used to use had removable reflective surfaces behind the (bulbs?/elements?) and it took everyone by surprise at the amount of effort involved in keeping the oven at peak performance.
Save
This Page (why?) - Home - ©1995-2009 finishing.com
