HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 52039
Mechanical polishing or passivation of Stainless Steel - which comes first?
April 30, 2009
Hello, Finishing Company - Rincon, Georgia ^- Privately contact this inquirer -^ May 1, 2009 Hi, Micheline. The mechanical polishing comes first, and then the passivation. The reason you don't need to passivate if you electropolish is because the electropolishing process (putting the component into a strong acid with an oxidizing electrical current at work) is pretty much the same thing as passivating (putting the component into an oxidizing acid) from the standpoint of de-activating the stainless steel. Regards,
May 7, 2009 Ted, - Rincon, Georgia |
First of three simultaneous responses -- May 8, 2009
Not if it is done correctly. There will be virtually no change.
James Watts- Navarre, Florida
Second of three simultaneous responses -- May 9, 2009
Mechanical polishing will give you the surface finish you require. This could be enhanced by electropolishing, which will also provide you with a better passivation than normally obtained with simple polishing. For instance, with stainless steel the passivation film is normally an oxide that will give a dull finish; electropolishing gives a brighter finish that is passivated by phosphate
Trevor Crichton R&D practical scientist The Pheasantries - Chesham, U.K. |
Third of three simultaneous responses -- May 11, 2009
The answer to that question is no. A passivation will not change surface quality :)
Bill GraysonMetal Finishing - Santa Clara, California
May 13, 2009
Thank-you for all the responses.
I did find a couple of scrap pieces that had been polished and was able to practice on them, and of coarse I found out that you are all correct. It did not change the appearance, but now I must be very careful of scratching.
I use Stainless Steel baskets and SS wire in my tanks. can I get any suggestions that would be less abrasive.
Sincerely,
- Rincon, Georgia
May 14, 2009
You can get plastic "pails" that have lots of small holes in them. Some places have different size holes. I would prefer polyethylene to polypropylene for resistance to the nitric acid, but PP will do. They are quite stout and will last for a couple years or more in normal use. Eventually, the oxidizing acids will make the pail brittle.
Also, they cost about the same as a good 316SS basket.
Electropolishing and passivation are both good for corrosion resistance of stainless steel, for different reasons.
Electropolishing produces a very smooth surface, and corrosion is best able to occur on rough surfaces. Passivation produces an iron-free surface with high amounts of chromium and chrome oxide, which is resistance to chemical reaction and protects the underlying iron. A electropolished surface that is then passivated enhances the corrosion resistance even further.
Nitric passivation can change the finish if not done properly, i.e. parts are left in too long. Citric acid passivation does not present that risk.
Ray Kremer Stellar Solutions, Inc. McHenry, Illinois |
September 18, 2009
Electropolishing or Passivation/Pickling comes after mechanical polishing. electropolishing shop - North Vancouver, British Columbia, Canada September 18, 2009 Hi, Cliff. I've never heard of passivating in nitric/hydrofluoric acid, but I've certainly heard of pickling in it. I think we're starting to confuse pickling with passivation. Regards,
October 8, 2009 Hey Ted, - north Vancouver, bc, Canada
