52000
Welding Copper Wire to Nickel Plated Copper
Ring
April 24, 2009
I am trying to weld a copper wire to a nickel plated copper ring.
I currently ultrasonically weld copper wire to a copper ring, but a
different application is requiring me to weld copper wire to the same
copper ring, however, it is being nickel plated first. The hardness
of the nickel plating does not allow for a good ultrasonic weld and
parts routinely have to be soldered post welding to help improve
strength.
I am looking into resistance welding with a brazing material. Does
anyone have any suggestions as to what kind to use. I have been told
a Sil-Fos material will work, however, I'm not sure which alloy of
Sil-Fos. Or could there be another material or method I should
use?
The wires must be welded post nickel plating and the strength of the
bond is an issue, regular solder isn't strong enough.
Steve Kruse
Engineer - Kokomo, IN
