HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 51094
Electroless nickel as applied to aluminium ?
January 29, 2009I need help in implementing the best process for electroless nickel on aluminum
Oscar Manuel Villalobos PerezPlating shop employee - Guadalajara, Jalisco, Mexico
First of two simultaneous responses -- January 30, 2009
Other than the items that will be listed in the operations sheet for the EN, the biggest help is a proper double zincate step. This is very hard to tell the quality, so be sure to get some qualified help from the vendor and run a bunch of test parts. An alkaline electroless nickel strike is of great help in getting a good EN coat.
James Watts- Navarre, Florida
Second of two simultaneous responses -- February 1, 2009
Clean and deox the aluminum, zincate in a dilute formulation, rinse, dip in 4 oz/gal Sodium Bicarbonate at room temp, rinse, strike in an ALKALINE ELECTROLESS NICKEL,rinse thru an ammoniated rinse water and enter the acid electroless nickel.
Robert H Probert Robert H Probert Technical Services Garner, North Carolina
February 2, 2009
High temperatures did not affect the electroless nickel deposit on the zinc, because of the coefficient of expansion of aluminum?
OSCAR VILLALOBOS- Guadalajara, Jalisco, Mexixo
