51079
Coloring Stainless Steel
January 27, 2009
I have a client that is interested in coloring stainless steel door hinges. I know
there is a method that will produce a gold finish when heated in a controlled atmosphere.
I am looking for temperatures, times, and atmospheric gasses.
R.V.Dixon
Ralph Dixon
Decorative Plating Consultant - East Berlin, PA
contact button
January 29, 2009
Good afternoon:
My guess is you will end up running trials to find the color match you're looking for. Once you find a color match, keep using the same stainless grade and processing parameters. The British Stainless Steel Association has a webpage that discusses this subject:
www.bssa.org.uk/topics.php?article=140
Steve Bizub
- St Louis, MO
February 23, 2009
PVD coating on stainless steel is the answer. TiN will coat these parts. You might want to consult www.svc.org and check with them regarding it. Good luck.
Michael Liu Taylor
   specialty stainless steel distributor
Dallas, Texas
Dear Reader
Post an answer
Post a question
Report broken links
List of Directories
