51064
Gold Chem-Film Finishing Different Shades
January 14, 2009
Currently in our chemfilm line we dip our sheetmetal parts consisting of steel and aluminum and sometimes parts on the same rack will come out in different shades. Does anyone know the reason for this?
Josh Valliere
Shop Employee - Cedar Rapids, IA, United States
contact button
January 27, 2009
Hi, Josh. Solution agitation is important for consistent color. Do you have air agitation or solution spargers? Tell us more about the presence of steel in this bath.
finishing.com
Brick, New Jersey
First of two simultaneous responses -- January 28, 2009
The reference to steel and chem film puzzles me as well, but I have found a good amount of variation in color due to alloy, surface finish (sanded vs blasted vs mill finish), and even though they go through the same process to clean, if one part had more in the way of soils or lubricants prior to clean, and now has some residues remaining in Chem-Film or affected prep in interim steps. More info would be good.
Paul Slater
- Cedar Rapids, IA, USA
Second of two simultaneous responses -- January 28, 2009
Iron contamination in the chromate solution will degrade corrosion protection, enough will fail salt spray testing.
Editor's note:
   Mr. Probert is the
   author of
Aluminum How-To / Aluminio El Como
Dear Reader
Post an answer
Post a question
Report broken links
List of Directories
