51060
Plating on coil, music wire springs?
January 14, 2009
I normally use music wire for making springs; But now the
requirement is different.
This is going in a sulphuric acid environment and also should deliver
high forces.
Has anyone got some experience on this? Also if you can suggest any
other material to achieve my requirement???
I tried using Stainless steel 304 grade but it is reducing the life
drastically. Is this a better option????
If I go for music wire with nickel plating????? Will it help?????
What would be the implications???
David Philip
Product designer - Noblepark north,Victoria,Australia
