finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 51051
How to remove cured epoxy adhesive from stainless steel
January 23, 2009
I am trying to remove or strip cured epoxy from stainless steel surface. I used NMP to clean it. Epoxy was partially removed, but stainless steel was corroded too. Can you recommend me some approaches to remove cured epoxy from stainless steel surface
Zhenwei Hou
electronics - Minneapolis, Minnesota
January 29, 2009
Hi Zhenwei. Please see letter 10780 -- I think you will find it to be the answer to your inquiry.
finishing.com
Brick, New Jersey
June 29, 2011
I just finished cleaning cured epoxy from an electric ducted fan with a Dremel and a wire brush bit.
The epoxy had dripped inside the fan unit and gotten on the fan blades and shroud freezing the unit.
Be very gentle and run the Dremel on its slowest speed.
David Longworth
- Kamloops, BC Canada
