![]() (Cycles thru suppliers) |
Robert H Probert Editor's
note: |
Sorry, you do not run a chromate tank by specific gravity as SG
includes the amount of water, acid, dissolved aluminum and any other
material like chlorides and sulfates. In short, it is grossly
unreliable as the tank ages.
It does not take much of a lab to be able to do your own testing for
both chromate and acid. You just need to train a couple of reliable
employees.
Hello Rob,
Don't forget that specific gravity can also go up due to iron
concentration.
At 2-3% is when I will change my tank out.
Micheline Forth
- Rincon, Georgia
My next question is the astm standard just says 20 to 25% by volume. Is that volume by weight or how is that measured? I am obviously no chemist, however I am very inquisitive. I will not stop until I figure this out. If I am using 42 degree Nitric in a 15 gallon keg how do I get a tank that is 350 gallons to be a 20% mixture? Knowing that the 42 baume nitric is 67.2% weight/volume I am not sure how to dilute it to the target mixture without using the same weight/volume. But is the astm spec calling for weight/volume or concentration/volume?
Rob Smith
- South Bend, IN
It means percent by volume of the commercial strngth of the acid. Easy. Non chemist needed until you get over 2%/weight of dissolved iron, then uyou will need outside instrumental analysis.
note: |
Mr. Probert,
Just curious, but what kind of bath loading is required to exceed
2%/weight Fe in a passivation bath? We run relatively small
quantities of steel, usually 15-5PH, through our bath for months and
barely exceeds 20ppm Fe. As a matter of fact, we only monitor Fe
because AMS 2700 requires it.
We are not a job shop and only perform captive processing, so that
may explain our low concentrations.
Terry Lycans
Aerospace - Dayton, Ohio
If you mean only HNO3 %volume,it is better to analyse HNO3 gms/litre by a simple titration with standard NaOH solution and calculating %Vol/Vol HNO3 by dividing the gms/litre HNO3 by the sp.gravity of the fresh solution of 25% by volume HNO3 solution and the dividing the product by 10 for percentage.Dissolved Fe may interfere with the observation of the end point.Color change may be seen only in supernatant clear solution.
Subramanian
Ramajayam |
Save
This Page (why?) - Home - ©1995-2009 finishing.com
