51043
250 micron Nickel Deposit With High
ductility and Low hardness(175HV)
January 23, 2009
We want to deposit 250 microns of Nickel from Nickel sulphamate
bath with high ductility & hardness should be around 175HV.We are
using Brass mendrel which is flash plated from Wood's Nickel bath
& further passivated with 3% Sodium Dichromate Sol. We need to
detach 250 microns electroformed Nickel from the mandrel prepared
above.
Kindly Help.
Suresh Bhardwaj
Plating shop employee - Punjab, India
January 26, 2009
I would be tempted to use a Sulfamate strike vs a Woods Strike
since you are going to passivate it. You might even consider a short
bake at low temp to passivate it before the chromate step. Whether
you can separate the electroform will be difficult on some parts that
do not get adequately passivated. You might need to use a thermal
step to get the release without damaging the product. Try several
scrap forms before you bet the company on a contract.
- FL
January 29, 2009
Personally I would use a stainless steel mandrel that is
passivated in 5% sodium dichromate solution for about 2 minutes. This
eliminates the problem of nickel plating the brass and it is just s
easy to machine as brass.
Sodium dichromate is not very nice to handle as it is hexavalent
chromium, so it is perhaps better to avoid it. In the case of
passivating the stainless steel, you can use 5-10% permanganate
solution, which is much safer.
As for a nickel passivation to allow the electroform to be detached
from the mandrel, why don't you use sodium metabisulphite (ca
150-200g/l) for about 15 minutes? This gives a nice blackish passive
film that is quite robust.
If you insist on your brass mandrel, I would certainly use a nickel
sulphamate flash, not Woods nickel - it is easier to use and more
compatible with your overall process
R&D practical scientist - UK
June 8, 2009
I have SS 316 one sided mirror polished mandrel for electroforming
nickel from nickel sulphatamate bath. I want to know which is the
best practice suited to DETACHED/ REMOVE safely the electroform from
the mandrel
the electroform thickness is 50 microns
regards
Hiren Sanghavi
plating shop employee - Bombay, Miaaharsatra, India
