Robert H Probert Editor's
note: |
Dear Mr.Michael,
I have worked in Industries as a Reasearch scientist depositing films
on Automotive components and later on worked as a Lead Aerospace
coating Engineer on Aerospace and Aeronautic Space Craft
componenents. Your quetion is rather interesting provoking me to
response to you. Thickness of deposits is a function of time, current
density, temperature and the concentration of the depositing species.
pH of bath is one of the most sensitive variable factors determining
thickness of electrodeposits that most people tend to neglect.
Bassey J.
Udofot |
Thank you all for your responses to my question. As a follow up
for Mr. Probert, how cool is cool enough when the bath is not in
use?
Mr. Udofot, for a manganese phosphate chemical conversion bath, what
is the optimal operating range for the pH?
Thank you all again.
Michael Costello
- Grand Junction, CO, USA
Michael, you do not have to contrrol "current density" in an immersion process like manganese phosphate, there is no electreoluysis to measure. Also, pH of a 200 F high acid manganese phosphate solution is not a factor. Start titrating the total and free when you get to 185F, do it right at the tank side, by the time you have the T/F ratio you will be at 195 (which is hot enough).knock out the free acid down to ratio with manganous carbonate, put the parts in, coat them, the industry talks in "coating weight" not in "thickness", when finished, cool it down as fast as possible. Some of the compound supppliers say to use Sodium Carbonate to reducde the free acid, that will work, but makes more sludge which settles out on the shelves. By using manganous carbonate you are at least replenishing the manganese and making less sludge!!!
Robert H Probert |
Bassey,
Manganese phosphate coatings are not electrolytic, they are immersion
processes. pH is indeed critical in the reaction mechanisms of
phosphate baths, but they are controlled normally by the free and
total acid measurements and possibly by the iron content.
Thickness can be time dependent where a reaction does not go to
completion (this is normally 5-15 minutes for most standard steels),
otherwise the limiting factor is in the growth during the reaction
phase.
Micheal,
There are so many factors that may affect your coating thickness as
mentioned already, may I added just a couple of others:
Surface pre-treatment - if you use a process that roughens and
increases the surface area this will increase your coating
weight.
Grain refiners - this will create smaller crystals that compact more
densely, increasing coating weight per unit area but reducing
thickness.
Just thought I'd add those into the mix.
The usual way to check that you have a sufficient coating is to
measure the coating weight. I would suggest you read MIL-DTL-16232,
it'll indicate how Military suppliers control their coatings.
Brian Terry
Aerospace - Yeovil, Somersset, UK
April 18, 2009![]()
Dear All,
Please help, i need to know how to convert the following unit of
measurement :
Zinc Phosphate 5 g/m2 is equal to how many micron ?
Manganese Phosphate 1500 mg/ftsq is equal to how many micron ?
Thank you in advance for your kind attention.
Rgds,
Hary
Hary Gho
Manufacturer - Indonesia
Save
This Page (why?) - Home - ©1995-2009 finishing.com
