51024
Galvalume Blackening without oxygen
deprivation
January 21, 2009
Recently, I have been investigating a heat of galvalume steel
coated coils received and roll formed into steel panels. The panels
produced were from only one identified heat and have developed dark
black streaks. The interesting part of this is that the panels have
been open to air and NOT in contact with moisture, but produced a
very definable, very dark stain.
I am familiar with Wet Storage or Black Stain and these are normally
explainable. However, this stain does not fit the description and
does not appear until exposed to sunlight. In all cases, the stain
was not prevalent when the material roll formed, but when exposed to
sunlight/heat it developed like a photograph during the day. Again,
the black stain that appears has not been subjected to oxygen
starvation or moisture.
Is it possible for iron imperfections or substrate problems to cause
this phenomenon?
Can the acid pickling process be defective or contain residual iron
effecting the galvalume coating process?
Can the chromium top coat be to thin or insufficient to create this
effect?
I would appreciate any thoughts or feedback regarding this
information.
Joe Snyder
Shop employee - Steel Supplier - Corunna, IN, USA
January 24, 2009
I once came across a case of black staining that developed only
with sunlight.
After investigating all manner of possibilities, it turned out to be
an employee with a water pistol (kids toy) filled with Silver nitrate
solution stolen from the laboratory.
Squirt it about a bit and it dried like water. But by next day -
black stains.
Geoff Crowley
galvanizing &
powder coating shop
Glasgow, Scotland
January 26, 2009
Sir:
Galvalume is NOT my area of experience. My best guess is that the
chromate coating is the problem. The aluminum content of galvalume is
so high, I cannot imagine that these dark stripes could be related to
"white rust" of regular galvanizing. In regular galvanizing with say
0.003% aluminum, if the chromate coating has too high or too low of
pH, then green, yellow, orange, gray, or black can develop a few
hours or days after chromate application. If you check with your
supplier, I expect you will find a poorly maintained chromate
solution.
