51015
Steel anode baskets are gassing in tank
January 21, 2009
my cy copper tank. what would cause iron baskets to gas when
rectifier is not on. I have changed my baskets to titanium baskets
now my tank will not plate copper it plates a silver color. I have
disconnected neg-positive from rectifier and now anodes are gassing.
this is a new solution my tanks are poly. I have taken heater, filter
and disconnected all power supply from tank and these anodes or iron
baskets are still gassing.HELP Please
Henry McCloskey
plating shop owner - New Orleans,La
First of three simultaneous responses -- January 22, 2009
Henry,
You seemed to have ruled out all equipment failures. I would make
sure you are using high purity, oxygen free copper anodes in the
bath. I used to stagger the copper anode baskets with steel anodes so
the copper content in the bath does not build up too fast. It sounds
to me you have severe case of immersion plating here. Something in
the solution is way out of whack. I would perform a complete analysis
on the bath. My gut feeling is the copper is way too high, or the
free cyanide concentration is way out of spec. I don't know if this
is a sodium or potassium based bath, make sure the NaOH or KOH is in
spec as well. Hope this helps you.
Mark Baker
Fellow plater - Syracuse, N.Y.
Second of three simultaneous responses -- January 22, 2009
You cannot use titanium baskets in a cyanide solution. The
titanium anodizes and will not pass current.
Third of three simultaneous responses -- January 23, 2009
Hallo Henry,
Don't be so surprised, it is quite normal. There's galvanic link
between copper and iron resulting in gassing on iron. In cyanide bath
iron is more noble metal than copper, therefore copper is dissolving
and iron is gassing with hydrogen. The more bigger surface of links
the more hydrogen. You use baskets, so the surface is very big. And
it's a big mistake to use iron baskets in cyanide copper plating,
because in cyanide solution iron is noble but not passive. It will
make oxidation of cyanides and dissolution of copper up to excess.
The right solution are titanium or plastic baskets or no baskets. Why
you observed white color after changing baskets into titanium ones, I
can't guess. Probably your bath has been contaminated. Iron baskets
were really wrong solution, but I can ensure that titanium ones would
be right.
Best regards
JANUSZ LABEDZ
- WARSAW, POLAND
