51012
Watts nickel bath contaminated with hydrazine
January 20, 2009
My nickel plating bath contaminated with hydrazine acidentally, and no good plating result, grey and no bright. what I can do to solve this problem??
Makky Abdul
director - Gresi, Indonesia
contact button
First of two simultaneous responses -- January 29, 2009
Hydrazine cannot and should not be treated with hydrogen peroxide. It would depend how much Hydrazine is in the bath, if it is above 200 ppm I would drum up the bath, label it accordingly, and make up a new bath. It is a probable carcinogen and is absorbed through the skin (at high concentrations). If you have it in your plant you should have a MSDS. Because of the oily nature of anhydrous Hydrazine (if that is the type), it is very difficult to remove from the bath. As you probably know it is sometimes used for a reducing agent in EN, but as I understand in very small amounts.
Mark Baker
Fellow Plater - Syracuse, N.Y., USA
Second of two simultaneous responses -- January 29, 2009
try to do a treatment with activated carbon in a ratio of 4 gms per liter it will help remove organic contaminants
Oscar Villaobos
- Guadalajara, Jalisco, Mexico
February 3, 2009
you can treat with low ampere (1-2 A/dm2), low pH(2-3), area cathode is highand about 45oC
Thang Quyet
furniture - Hai Phong, Viet Nam
Dear Reader
Post an answer
Post a question
Report broken links
List of Directories
