51009
Bathing resin castings in precious metals
-- what's it called and how do you find out about it?
January 21, 2009
I am new to silversmithing and metal terminology, however as a
sculptor with resin casting experience, I recently came across a
silver-plating process that peeks my interest, used on some
Italian-made sculptures I found offered on eBay . It involves
creating a resin-cast object which is then bathed in baths of (pure?)
silver, then copper and then sterling silver (and then possibly
gold). First, what is the technical name for this process? Second,
what specific type of polymer resin is used to withstand the high
heat? Third, are there any chemical or non-chemical treatments
involved? And, fourth (an idea), couldn't you cold-cast the resin
mixed with copper powder to help bond the silver to the object
(perhaps even saving the copper-dipping step)?
Here is an excerpt of the description of the process found on
eBay:
"A liquid polymer resin is poured into the negative mold and takes as
much as 10 days to fully cure. Some pieces have several different
molds for different sections or parts. When the positive strike is
completely hardened, it is removed from the negative mold and
attached to other parts of the piece, if any...
"Applying silver is a difficult and labor intensive process. Unlike
"silver-plated" items which are only dipped for a few seconds in
silver, allowing for the silver color to eventually wear away, the
process used on this item calls for several days of bathing and
coating in silver. The bathing creates a high content of silver on
the surface of the strike that never wears away and adds value and
luster to the piece. Next, the resin strike is bathed in copper
making the strike an attractor for the silver. The strike is then
bathed in pool of .925 sterling silver for several hours, or even
several days. The strike is removed from the molten silver and after
it completely cures, it is polished by hand and coated with a varnish
to prevent tarnishing. The content of silver in most pieces ranges
from a few grams to a few ounces depending on the size of the piece.
The pieces that have a gold coloration are made with actual 24 karat
gold using a special heat burnishing gun that melts the gold over the
silver. After their silver bath, pieces that are completely gold
colored are actually bathed in 24 karat gold. Most pieces take a few
weeks to complete. Some take a few months. Each piece is stamped .925
silver, and most pieces have a factory or studio identifying mark.
Some are also designed by the original artist."
Eric Reagan
sculptor - Brattleboro, VT, USA
