51008
Setting up a small scale nickel sulfamate
bath in a university
January 20, 2009
I am currently a student working for the University of Canterbury
in New Zealand. My supervisor has asked me to investigate the in's
and out's of setting up a small scale Nickel Sulfamate bath to plate
electroforms. During my research I have compiled an electroplating
solution formula by looking at papers from 1954! The solution is
relatively simple consisting of Nickel Sulfamate, DI water, boric
acid and a wetting agent Lauryl Sulphate. The electroplating tank
will most likely be a 400 ml beaker to give you an idea of the scale
of the electroplating station. My supervisor has told me the
University has the appropriate hazardous chemical disposal methods
etc. Is there anything else I should be considering before I advise
my supervisor on how to setup this station?
Peter Cowan
Researching Student - Christchurch, New Zealand
January 21, 2009
Hi, Peter. Temperature control and agitation are important, but
probably no problem to do with a hot plate and magnetic stirrer for
such a small container. An issue you haven't talked about is the
material of construction of the mandrel (wax, aluminum, stainless
steel, etc.) Good luck.
finishing.com
Brick, New Jersey
January 29, 2009
Electrofoming in a 400ml beaker is going to cause you lots of
problems, so don't start it. You will need at least 4 litres and that
will be for a small electroform. You will need good temperature
control (+/- 1C), filtration at about 10 tank volumes per hour,
sulphur nickel rounds as anodes, good current control, bath
agiotation, good workpice preparation. The list is endless, so read a
book on electroforming before you embark on it.
Good luck
R&D practical scientist - UK
