HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 51003
Passivating heat tint areas
January 20, 2009In fabricating frames using 316L pipe with six welded joints there are areas of heat tint which require pasivation. The extent of the welding is minimal, 10 linear feet and restricted to the corners and two locations mid span.
What method of passivation would you recommend to accomplish this passivation?
John
Job shop employee - San Diego, California
February 12, 2009
John,
For something like that the easiest thing to use is a citric acid based passivation gel or a nitric acid based pickle paste. Let us know if we can help.
Ray Kremer Stellar Solutions, Inc. McHenry, Illinois |
