letter 5101
Duplex nickle and chrome plating on
stainless steel.
We are a high volume production, chrome plating company supplying
into automotive industry. The automotive companies have increased
quality standard. Our problem is with duplex nickel and chrome,
plated onto stainless steel. Inconstistant adherance of nickel to
base metal. (plating peels off)All parts on flight bar peels, not
just individual parts.
Our current process (excluding water rinses):
- 1/ soak clean
- 2/ elctro clean
- 3/ cathodic sulphuric acid etch. 30% acid. 5 amp per square
foot.
- 4/ semi bright nickle
- 5/ bright nickel
- 6/ chrome
When we add woods nickel strike operation, after acid etch, we
solve peeling problem but experience roughness, which is now deemed
unacceptable to auto industry. Nickle strike operation is cathodic
and we have bagged carbon anodes. solution is filtered continously.
It is our understanding that if process is correct, you should not
require a etch and then a strike operation.(you should be able to use
either one. I am asking if anyone has experienced the same problems
and what would some suggest solutions be.
Michael Hayward
- Adelaide, South Australia, Australia
First of two simultaneous responses
We acid etch and Wood's strike our stainless parts. Using the
strike is insurance so to speak. You should not be getting roughness
out of the strike, though. Keep in mind that a Wood's nickel, like
other strikes, is relatively sacrificial and should be made up new
relatively often. Are you putting a lot of grit blasted parts through
the strike and introducing media to the solution? Also what pore size
filters are you using? If they're too large, they're useless.
Megan Pellenz
- Syracuse, NY
Second of two simultaneous responses
Keep your acid etch. Get rid of the carbon anodes. This is about
the worst possible thing that you can put into a Woods strike tank.
Use rolled depolarized cast nickel anodes. McGean Rocho is one of
the few companies that still cast them. Bag these and change the bag
at least quarterly and every two months would be beneficial. Change
your filter elements every couple of days untill you do not show any
more black stuff on them.
Personal preference is to run the HCL aon the middle of the
recommended and the nickel on the low end. Optimum adhesion is at 90
-100 ASF, but it falls like a rock at 110ASF, so I would use 80
-90ASF.
This tank system will generate nickel ions, so dont be cheap. Bail
some out and replace the volume with an appropriate amount of HCl and
water.
You should have absolutely no problem with peeling strike. Strike
long enough to see color. That is all it takes.
If you do the above, you should not have any problem with
roughness. If you do , increase the flow rate thru your filters
rather than going to a finer filter media.
Jim
Hi Michael ,
The answer lies in the amount of time & current density used
in the WOODS nickel Strike , as this process does not use any
Brighteners , levellers if used for too long it develops what appears
to be roughness but is actually nodulation . Cure is to check
everything , Anodes , anode bags , they should be double or napped
polypropylene , is the filter effectively filtering the solution ,
you are not just taking from & delivering to the same area of the
tank are you ?
regards
John Tenison - Woods
- Victoria Australia
Dear Reader, please --
- Post a
question on a different
subject.
- Answer or follow-up on this
subject (in non-commercial
fashion).
