![]() (Cycles thru suppliers) |
Ted´s advise is the way to go, but in the mean time I will
try to answer your questions.
1- You are supposed to use long fiber cottton and pull it to wrap it
tight around the anode. If you cut it in short pieces, it tends to
loose and move or un-wrap during processing (anode sleeves are not
enough to keep it tight)
2- The color of the cables is theoretically irrelevant. As long as
you connect the brush to the positive terminal on the power pack and
the part to the negative for plating (FORWARD). Of course, etching
and some cleaning steps on some metals require REVERSE polarity. Then
the brush is negative and the part positive. If you make a mistake
you may ruin the part. For instance if you use forward polarity when
cleaning a high stength steel you may induce hydrogen embrittlment in
the part. If you use reverse with an acid solution you may dissolve
metal from its surface instead of plating it or building it up.
3- The best vendors advertise here. Just take a look.
Guillermo Marrufo
Monterrey, NL, Mexico
Hello,
I am Bob Brookshires last stepson and a former employee of
Brushtronics Engineering.
From my memory Guillermo Marrufo's answers #1 and #2 are
correct.
Found this thread through a random Google search. Hope Guillermo's
answers are helpful.
JW
Jesse Woods
- Laurel, Maryland, USA
Save
This Page (why?) - Home - ©1995-2009 finishing.com
