50077
Stripping powder coating
September 23, 2008
I am restoring a 1955 panhead the shope that powder coated my hubs
also coated the bearing surfaces what is the best way to get the
powder coating off.
Chuck Cain
hobbyist - Fridley, MN, USA
September 26, 2008
Here is how I do it. I use a paint stripper with methylene
chloride in it . This stuff is dangerous to work with. If you get it
on your skin it will burn like heck. If you get it in your eyes you
have to start flushing them out with water immediately while you have
someone take you straight to the hospital.
I prefer the liquid because the paste type does not get into the
nooks and crannies very well. I pour the stripper into a stainless
steel bowl. Then place the hub in the solution for about an hour.
Then remove it from the solution and rinse it thoroughly. At this
point the powder coating may start coming off or at least begin to
blister up. It depends on how tough the powder coating is. Then I
bead blast as much of the loose coating off as possible. In some
cases I have to repeat these steps quite a few times before all the
powder coating is removed.
If you really want to try you can buy paint strippers with methylene
chloride in them at most hardware stores. But without a high output
Bead Blaster [link is to product info at Amazon] it could take
a very long time and a lot of work to strip your hubs. Be very
careful and follow the directions that come with the paint stripper.
Especially the directions about safety.
