50061
Mixing sodium di-chromate in passivation
September 16, 2008
For types 1, 2 and 3 passivation, what should the concentration of
sodium di-chromate should be in the bath? Is it the same
concentration for all three types or different?
How many pounds per 100 gallons for the concentration?
Thanks everyone!
Mike Davis
shop employee - Kalispell, Montana, USA
September 22, 2008
Hi, Mike. It's probably about one-half percent to one or two
percent, with the higher concentration being for the deeply colored
chromates and the lower concentration being for the clearer
chromates. There are also usually accelerators present and fluorides
sometimes as well. You can find something about the formulation of
chromate conversion coatings by going back to the mid-fifties when
the basic R&D work was published, but these products have been
primarily proprietary for decades now. Is there a reason you are
trying to use home-brew?
finishing.com
Brick, New Jersey
November 24, 2008
Which specification are you referring to? ASTM? Is this for
stainless steel passivation or Al chromate conversion?
Terry Lycans
- Dayton, OH, USA
