finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 50057
Percentage of nickel in zinc-nickel acid, alkaline and sulphate baths
September 23, 2008
this question is of interest as we require the correct quantities as we require to start the bath.
Mitesh Gosalia
plater - Goa, India
September 26, 2008
That information would be contained in the vendors technical data sheet. If you are not using a proprietary formulation then you need to experiment yourself.
Gene Packman
- Great Neck, NY
September 29, 2008
HELLO SIR,
Generally alkaline zinc baths contains 10-15 percent of nickel and rest is zinc.
Shoban Kesarapu
    plating chemicals supplier
Secunderabad, A.P., India
October 7, 2008
For good corrosion resistance, the higher the nickel conent up to 15%, the better. However if a post treatment such as a chromate, Hex or try chrome, is requirred 9 percent nickel is suggested. Higher nickel content makes it difficult to obtain a good resistant finish of the post treatment.
Don Baudrand
Don Baudrand, Consultant
Poulsbo, Washington
