finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 50037
Floor covering for anodizing line
September 17, 2008
I would like to know what is best suitable for the floor covering at anodizing lines that can be resistant to all the acids that might be used at the anodizing lines.
And also by considering the heat on chemical brightening tank and sealing tanks what has to be used as floor coverings on these specific areas too.
Ismail Tutlupinar
Buyer - Istanbul, Turkey
September 22, 2008
Hi, Ismail. Vinylester or epoxy troweled-on coatings should be fine. But the bright-dip tank should be double-walled so there is no chance of a massive spill in the event of a leak at the welds.
finishing.com
Brick, New Jersey
September 23, 2008
We use non-slip 1" thick fiberglass grating for the flooring/grating surrounding the tanks at my plant. The initial investment can be quite steep, but it will last a lifetime, and you don't have to worry about stripping and re-coating when the coating on the metal grating inevitably fails.
Marc Green
anodizer - Boise, Idaho
1
