finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 50004
Plating to meet 1000 hours of salt spray?
September 15, 2008
We supply automotive parts to some of the OEMs in Europe. Recently, we received an enquiry from one of our customer for new business. However, the part must meet 1000 hours of salt spray test.
Please suggest what kind of plating will meet this specification. The plating chemical should be free from all heavy metals.
Thanks and Regards,
Venkatesh
Venkatesh, Krishnamurthy
Automotive - Chennai, India, Tamilnadu, India
S
I
M
U
L
T
A
N
E
O
U
S
R
E
S
P
O
N
S
E
S
September 19, 2008
Are you currently supplying parts to customers that require parts be plated to 1000 hours of salt spray?
matt heylock
delphi - amherst, ny, us
September 19, 2008
Mr.Venkatesh,
Please specify whether SST hours for WR or RR. Reg heavy metals free then it should be trivalent chromate. Also any specific chromate colour requirement.
P. Gurumoorthi
    electroplating process chemicals
Chennai, Tamilnadu, India
September 22, 2008
Dear Mr. Venkatesh,
Zinc-Nickel plating with minimum 10 micron thickness followed by trivalent passivation and top-coat will give you 1000 hours to red rust.
Alternatively you can try zinc-rich dip-spin coating which gives 1000 hours SST.
Both the above process will meet the ROHS requirement.
Vara Ramesh
- Chennai, Tamil Nadu, India
September 29, 2008
HI SIR,
I think alkaline zinc-iron plating followed by trivalent black passivation and sealent will give you 1000 hrs sst.Try with that
good luck
regards
Shoban Kesarapu
    plating chemicals supplier
Secunderabad, A.P., India
October 3, 2008
Dear Venkatesh,
Please tell what the colour of finish you need. There are zinc rich paints which give more than 1000 hours easily. That comes in grey and black colours.
S.V. Aurobind
plating process supplier - Bangalore, India
November 13, 2008
Dear Venkatesh,
Based on the part application we need to select the surface Treatment. we will do Zinc Alloy plating,Organic Coating(Ex-Geomet,Zintek) and Nylon Based powder Coating, or Paint in CED/Spray method we will do.
Is the thickness is low only possibility Plating with proper method, Thickness is not a problem we will go for Nylon Based powder coating. You will get all type's of Surface treatment supplier's In chennai.
Is you are selecting the organic or powder coating. please do the Zinc plating with out passivation and then do the organic or paint coating
Kannan B
- Salem, Tamil Nadu, India
