Letter 5076
Dilute Chromate
Alright, this is a good one!
We make aircraft wings, and I have a problem with what I think to
be the dilute Chromate sealant, first all wing parts go through
anodizing and in the end they are dipped into the dilute chromate to
act as a sealant (we no longer use the hot water seal, from there
they are passed along to paint shop where they are masked. This is
where the problem comes out, where the masking tape was directly on
the wing skin, a yellowish color is left behind, which Im pretty sure
is dilute chromate, but like I said its only where the tape was
applied, where the paper was put at use its alright.
Am I missing a process somewhere, should pieces be air-forced
dried before masking? should pieces be shower rinsed after the
chromate application??
I also noticed that this problem is causing me adhesion
problems!!! If anyone knows this one, let me know on somekind of
test, cuz I went through plenty of testing and Im stumped on this
one.
Terrence Double
- Momtreal,Quebec,Canada
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject (in non-commercial
fashion).
