Letter 5075
Chrome Plating plastics
I am carrying out a project to improve the VolksWagen Beetle
headlamp. It is currently built entirely from metal, but i would like
to look at the possibilities of manufacturing the rim of the lamp
from ABS or Polypropylene.
How much would a chrome plated ring of 15cm diameter cost to
produce on average ? and would it have better corrosion resistance
compared to chrome plated mild steel, which is currently used. Do you
also know the average lead time for chrome plating such a part.
Adam Goodfellow
- Coventry, United Kingdom
The majority of grills, headlamp bezels, and tail lamp bezels are
chrome plated ABS, so you won't be tilling new ground. The corrosion
resistance, whether the substrate is steel or plastic, will be
outstanding and not an issue if a really high quality duplex
nickel-chrome plating system is used.
Sorry, I don't know the usual cost, although the overall cost of
the item will be lower in plastic. Lead time would certainly depend
on volume; a prototypist could do a few this weekend if you made it
worth his while, whereas a major production run involves
displacing/delaying someone else's work and could take several
months.
Ted Mooney, P.E. - finishing.com inc. - Brick, NJ
What would be a typical a value for the resistivity of chrome
plating applied to plastics (PC/ABS)? We want to use the chromed
inside the case for RFI shielding, and need to compare it with other
technologies. The thickness of the materials used to finish the
plastic case are:-
Cu 5.0 microns
Ni 8.0 microns
Cr 0.1 microns
Raymond Yu
- United Kingdom
Just a quick question. Do you know of any way to chrome PET?
Richard Mills
- London, England
Your question is problematic, Mr. Mills, from the aspect that "to
chrome" means different things to different people. To some it means
very literally to electroplate with chromium; to others it means
merely "to make it reflective, metallic, and shiny looking". So, do
you merely want it to look like a reflective mylar party baloon or
must it be electroplated with chromium.
Your question was quick, alright, much too quick
You really need to explain in pretty good detail what you want "to
chrome" and why.
finishing.com
Brick, New Jersey
Dear Reader, please --
- Post a
question on a different subject.
- Answer this question (in non-commercial
fashion).
