Letter 5045
Cyanide Zinc Problem
We are doing cyanide inc plating on hollow pipes of dimension: Internal Diameter : 2 inch Length : 18 inch
The test report of steel being plated is as follows:
  • Carbon : 0.078
  • Silicon : 0.038
  • Sulphur : 0.017
  • Phosphorus :0.0225
  • Nickel : 0.003
  • Chrome : 0.009
  • Molebedium : 0.005
  • Aluminium : 0.037
  • Cupper : 0.009 &
  • Lead : 0.001
We have made a fresh plant and it was working perfectly OK for 3 months on 16 hrs working daily. But after 3 months we are getting, a blakish tone of zinc deposit. The blackish zinc deposit can be rectified by treatting the solution with Zinc Dust after every 10 days.
After 6 months the solution is not in a condition of working and we have to discard the whole solution.
The composition of the plating bath is as :
  • Zn as metal
  • 25 gm/ltr Cyanide
  • 70-80 gm/ltr Caustic:
  • 60-70 gm/ltr
please suggest the origin and the remedy of this problem.
Dharam Vir Singh
- Noida, (U.P), India
I assume that you use sodium sulfide (Na2S) at least one a week to overcome the dark deposit. If the deposit comes out bright from the plating solution and gets dark in the nitric dip or in the chromate, it means that you need sulfide. The fact that you need zinc dust indicates that you have some sort of contamination. I would guess it is copper. Maybe you clean the buss bars that are made of copper and this way you contaminate the solution.
Sara Michaeli
    chemical process supplier
Israel
Dear Mr Singh,
NEVER discard a cyanide zinc bath as almost anything but severe chrome contamination can be treated.
Do's and Don'ts for trouble free CZ plating:
Don't : Ever premix Sulphide based purifiers with brightners as purifiers are meant to form a sludge wich precipitate metallic impurities, but in doing so also sponge out brightner content leading to dark deposits you have seen.
Do : Ensure that you have at least 18 inches clear from the bottom of your tank till the bottom of your component so as to not stir up the sludge by convection caused by loading/removing the components. Sludge mixed up with clear solution can cause dark deposits.
Do : Have a daily dummy run at 2 Amps /sft every night as you are plating hollow tubes and will cause a higher than normal iron content in the tank. Dummying your bath every night will also remove out any other metallic impurites such as lead , copper which tend to come out of dried oils found inside of pipes not entirely removed in the precleaning stages.
Dont : Clean your copper pipes on the top of the tank. Have SS bolts at the ends which allow easy dismantling and emery or Acid pickle the pipes away from the tank.
Do : Try 2 gms / lit of Sodium Metabisulphide treatment if all this fails as this works to remove chrome but a chrome contamination will manifest by showing no deposit rather than dark deposit.
My bet is on copper and lead contamination. Try the dummying and fornightly sludge decanting which should take care of your dark deposits.
regards,
Khozema Vahanwala
Automaxx
Bangalore, Karnataka, India
Dear Mr. Singh:
The very first thing that I would do, is to get an Atomic Absorption analysis of the Copper, Lead, Chrome in your plating bath. Normally, for the sake of chemical conservation and safety, platers will not discard a plating bath this easily.
The Sodium Polysulfide (also called Zinc Pure or Zinc Purifier), is added at the rate of 2 mls/Liter but not more than once per day. You can test for this product easily using a freshly made 5%(by weight) Lead Acetate solution. This will precipitate the copper and lead, BUT NOT IMMEDIATELY. Sometimes the precipitation may take 24 - 48 hours to be complete. Don't stir up the sludge at the bottom of the tank. If you rake the tank, allow it to settle for as long as is practical in your shop.
You may also choose to run a Hull Cell of your bath the way it is now. Make up a liter of Cyanide Zinc in your laboratory at Normal make up as suggested by your supplier. Run panels as follows:
  1. Full strength bath as it is NOW and zero % new bath
  2. 75% your current bath and 25% New solution (Mixed)
  3. 50% your current bath and 50% New solution (Mixed)
  4. 25% your current bath and 75% New Solution (Mixed)
  5. 100% Brand new bath.
When these panels are plated and test chromate passivated, you may lay them out on a desk to see what dilution it took to make your solution look normal again. One last tip. Use the best quality Zinc anodes that you can. Some platers use the same type as they use for Alkaline Non cyanide Zinc, and that is 99.9995 % pure Sincerely, Ed
Ed Budman
- Pennsylvania
THE MAIN PROBLEM FACED BY YOU IS AFTER 3 MONTHS IS DUE TO LACK OF PLATING THICKNESS IN THE LCD AREA. THIS IS DUE TO LOW METAL CONTENT AND LOW CYANIDE CONTENT. PLEASE MAITAIN 34 GMS\ LTS ZINC METAL AND 110 GSM OF SODIUM CYANIDE SO THAT THE SELF CONTROLING OF IMPURITIES TAKES CARE OF BY CYANIDE AND AS A RESULT THE LCD AREA GETS PERFECT COVERAGE REMOVING TRACES OF IMPURITIES WHICH HASD NTO BEEN REMOVED ELECTROLYTICALLY . WE SUGGEST HCL ACID PICKLING WITH 1% ACID INHIBITOR FOR A MINIMUM PERIOD OF 30 MINUTES WHICH LEADS TO PERFECT CLEANING AND DESCALING AND ALSO AVOIDS HYDROGEN EMBEDDIMENT INTO THE METAL.
FURTHER AN ELECTROLYTIC METAL CLEANER USAGE BOTH AS ANODIC AND CATHODIC FOR 30 SECONDS AT 12 VOLTS CURRNET SHALL DEFINETLY LEAD TO PERFECT CLENAING WHICH RESULT IN ACCEPTANCE OF ZINC PLATING TO THE HIGHEST BRIGNTNESS LEVELS.
WE RECOMMED ZINC CYANIDE IN THE PLACE OF SODIUM CYANIDE TO GET EXTREME AND EXCELLENT RESULTS.BETTER USE A BRIGHTNER WHICH CAN WORK FOR HIGH CYANIDE AS WELL AS LOW CYANIDE BATHS.
C PRAKASHAM
chemical co. - KOLKATTA, CHENNAI, INDIA
Dear Reader: please choose what you want to do.
I want to post a question or inquiry of my own.
I want to answer or follow-up on this question publicly (in non-commercial fashion).
I am a supporting advertiser and want to reach the inquirer privately.
