Letter 5034
Reworking Chrome plating on Nickel
plating.
Hello,
As a commercial plating shop, we generate about 2 -5 % of our
Nickel Chrome plated parts with Chrome burning at the edges. Classic
cases are car seat headrest rods whose tips jut out .
Our problem lies in reworking these rods with chrome plating
without peel off. Presently we strip the chrome off in HCL and anodic
etch in NaOH solution prior to Chrome plating. Does anyone have a
better suggestion ?
Help is as always much appreciated, thanks in advance
Khozema
Vahanwala
Saify Ind
Bangalore, Karnataka, India
I would assume that it would be cheaper to prevent the burn by
rounding the corners of the rod, lowering the high current density
area, or using a thief, probably a piece of stiff wire or a shield,
probably an appropriate length and diameter piece of pvc pipe
appropriately attached and positioned.
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject (in non-commercial
fashion).
