Letter 5024
Michael Liu
Taylor |
Kevin:
A great deal depends on the size, shape and metallurgy of the parts you are working on. Very low Ra finishes can be developed on a variety of metals utilizing successively finer abrasive materials in sequence.
If your parts are random or non-flat in shape using a loose abrasive method such as centrifugal barrel polishing can produce low single digit Ra microinch surfaces with high reflectivity and image fidelity. These kinds of process may not be appropriate if the surfaces you are trying to work have larger broad flat areas. If this is the case you might want to consider precision lapping.
David A. Davidson
- Bartlett
I don't think chrome is much used as an optical surface because of its high absorptivity. Although chrome is specular, it's dark. Silver plating (or ideally rhodium plating) would be better, or aluminum sputtering; or you might make the mirror from chemically polished or electropolished aluminum. Good luck.
There are lots of site that I have visited that give step by step instruction on how to... Don't we all feel that in this community we should have a similar page where all the contributor input their expertise. Finishing companies usually require large and repetitive orders leaving the small batch finishers in the quandary. Any suggestions.
Haider Bilgrami
Insi - Singapore
We have more than 12^50 thousand topics on line here, Haider,
and we'll be happy to take any thread as deep as you want.
But my experience is that, no matter how great the willingness to share, public forums are not a substitute for books, because a topic can't be presented in orderly tutorial fashion without the months or years of planning that book writing involves. Cogently writing the book is a far bigger job than accumulating the information. But ask a specific question and we'll all try to help.
Ted Mooney finishing.com Brick, New Jersey |
Save
This Page (why?) - Home - ©1995-2009 finishing.com
