HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 5009
Stripping pitted pot metal parts
I was wondering if there is a better way to strip plating off of pitted automotive Pot metal. Currently I am using mechanical methods (grinding, buffing, sanding). My acid pickles that I use to strip steel parts eats the pot metal. I've tried glass bead also. Is there a better way? Thanks Tom H.
Tom H [last name deleted for privacy by Editor]- Peoria Arizona usa
September 28, 2008
Hi, Tom. Please see letter 12885 for ideas on this. Good luck. Regards,
