Letter 5007 Stripping titanium nitride PVD coatings(2000) Seeking a source of a stripper for PVD coating (titanium nitride). A variety of substrates is involved. Thanks
(2000) Concentrated acids, especially hydrofluoric, will dissolve PVD TiN. It is even more difficult remove CVD TiN due to the more conformal surface. Unless your substrate is glass or ceramic, there is a strong likelihood the substrate will be significantly damaged removing the nitride with this method. Sorry, that is one of the advantages TiN surfaces--the fact that they are so hard to remove! Dale Woika
(2001) A combination of alkali and hydrogen peroxide are useful for removing titanium nitride from stainless steel (I would recommend a 5% (w/v) of KOH to which is gradually added approx 30% hydrogen peroxide solution (no more than 20 L to a 100 L KOH solution). The H2O2 is added slowly so as to control the temperature of the etch solution. If the temperature of the solution exceeds 30 deg C oxygen is evolved rapidly and the solution will foam up uncontrollably. Ammonia solution can be substituted for alkali (KOH/NaOH) for etching titanium nitride from aluminium. Brendan Timmins
(2002) Also seeking a solution for removing PVD TiN. Without damage to the underlying ceramic (AlN) substrate. Jason
(2003) I run a PVD job shop in India. Most common method for stripping Titanium Nitride is to use 30% or 50% hydrogen peroxide (H2O2) - this works with stainless steel and HSS substrates. But this is slow; will take up to 8 hours. Use a container big enough to allow for foaming and also keep it ventilated; keeping it in sunlight speeds it up. Catalysts such as NaOH and EDTA speed up the process, but needs more control. For stainless steel 304 grade, nitric acid + HF works well - over in minutes - but you have to be careful with concentrations (we use 3:1 ratio) to avoid etching of substrate; with 410 grade; we tried, there was heavy etching. Right now we are staying with H2O2 Caution: do not use with tungsten carbide. Kuppu Swamy I work for a PVD company that deposits hard coatings such as TiN
or TiAlN on steel substrates. We developed a stripping process which
is a mixture of NaOH and hydrogen peroxide (H2O2). Steve Guetre
September 12, 2008 I am a bit surprised that you did not have any problem in the lab
at 70C. James Watts
Dear Reader, please --
Save
