49094
Adverse conditions in Hydrogen generator
diodes causing problems with metal corrosion.
June 21, 2008
Hello, I am an individual with limited technical knowledge, but I
am over flowing with determination. With Gasoline prices soaring, I
am taking on the challenge of making hydrogen on demand to assist
with gas mileage. My goal is to overcome the obstacles I have seen so
many others faced with. One of these challenges are heat build up and
water pollution making their systems inconvenient to operate. I am
looking for some advise in finding the best metal available for the
electrical contact plates in the Hydrogen Generator. This is where
the heat and pollution is coming from.
Producing hydrogen through electrolysis, (passing water between a
negative and positive charge to separate the hydrogen from the
oxygen), is creating a problem with the materials being used as the
electrical contact plates. This process brings out the impurities of
the metals I have been using. Trying to keep cost down, I have used
aluminum, copper, stainless steel 300 series, tungsten and 99%
nickel. The Tungsten held up well, but a 5x6 plate 1/16 thick cost
approx.$300 and a total of 6 plates will be needed. The Nickel is
holding up well but the test is on going.
It has been suggested I use the 904L stainless, or titanium. I have
not priced either of these as of yet. I have already incurred allot
of expense doing the trial and error routine. I am hoping someone
will know the best metal to use for this application without just
purchasing more metal and hoping it works.
I am using 14 DC volts around 2 to 4 amps. The metal is submerged in
water. I am using distilled water adding distilled vinegar as
electrolytes to bring the amps to the desired level.
William Thomas
Private inventor/user of metals/fabricator - Bolivar, Missouri,
USA
