49085
Drying process for waste zinc phosphate
sludge
June 20, 2008
The removal of zinc phosphate have become a nightmare with rising
costs, is there any one attempting to dry this waste off before it
consigning out, if so I would interested to know what method would
best be used, remembering Health and safety practices.
Many Thanks
Pauline Burley
Process Technician e-coat - UK
June 21, 2008
Look into filter presses. Phosphate precipitates are a slimy mess,
so watch which filter "cloth" you use. Also consider using magnesium
oxide for the initial portion of the neutralization. ( a less messy
precipitate) It is barely soluble, but will react fairly well with
acids, so it will work well to say a pH of 5. Polish the pH with lime
or with caustic soda.
A small filter press should work for you. See if you can find a used
one that is in good condition with a warranty on the pump. If you can
get to Sur-Fin, you can get a great discount on their show units
because they do not have to ship them home. OOPs, you are in the UK.
There should be a major show in Europe somewhere this summer.
The only thing I can add to Mr. Watts' excellent advice is to use
a diatomaceous earth precoat on the filter press plates. This always
improves the ease of cake release from the press plates, and can help
with the clarity of the press return water.
Dave Wichern
- The Bronx, New York
