49079
Material used for sand blasting in aviation
field
June 19, 2008
hi,
I am from Dubai I have a question which is being appeared in general
civil aviation authorities quistnair for couple of times, what is the
proper material used for sand blasting. Cheers.
Regds
Kamran Saeed
-Dubai, UAE
June 20, 2008
Sand can be used, but it breaks down fairly fast, so it needs to
be changed more often. In the USA, it in not used very much because
of our federal safety regulations concerning silicosis (breathing
silicon dust).
Probably the best is silicon carbide, but it also contains silicon so
is not used as much as it could be. The paper work that goes with its
use is a pain far greater than the actual precautions used.
That leaves aluminum oxide. Brown is cheaper than white, but white
lasts a good bit longer and I believe that it is in the long run more
cost effective.
Aluminum oxide also has a benefit of dissolving in a caustic cleaner
tank, so you do not have particles embedded in the parent material
causing surface roughness.
The real answer is you need to use whatever material is specified in
the overhaul or OEM specifications.
Add to James list. Glass beads are very common in the industry.
