finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 49040
Problems with chromium bath
June 16, 2008
Hello, I'm Carolina Alvarado I'm a student of Chemical Engineering, actually I'm working in my Thesis topic and it's about electroplating on ABS, in my country Colombia this process may be is a little backward respect the world industry, but I hope that change. In the plant where I work we have a problem with Chromium bath, because we want give more time in the bath but is imposible, because the pieces tend to burn, actually the bath conditions are:
Chromic acid: 250 g/l
Sulfate: 3 g/l
Temperature: 35 -45 ºC
Time: 1 min
Current density:5 30 Amp/dm2 (depend de catode surface)
could you help us please we don't know what is the problem...
Carolina Alvarado
student - Bogotá
June 18, 2008
Pieces burn because they are being run at too high a current density, not because of the time in the tank.
We are also using chromium bath in our ABS plating process, the failure of chromium bath can be easily seen from the hull cell test.. we always use this test to see the bath condition.. and generally te amount of the H2SO4 in the bath cause problems then we add BaCO3 to our bath. Also the amper that u use is seeming too much to me..
regards ..
Eren Sakar
- Izmir, Turkey
