49019
Color of CED paint
June 12, 2008
Why generally OEM industries using Black or Grey CED paint? If we are using red or blue CED paint then what kind of problem create in regular painting process?
Bhavesh. Joshi
paint technologist - Gujarat, India
July 2, 2008
Absolutely no problem if you develop the CED paint color may be blue or red with your Paint supplier. How ever there are separate stages for CED , UF1 , UF2 & DM rinse stages are required.
You can do a Epoxy Grey ED followed by UF rinses then Acrylic top coat ED and rinses.
Thanks & Regards,
P.M.Saravanan
   paint shop manager
Chennai, Tamilnadu, India
July 19, 2008
CED coating and its development has been intertwined with the automotive component surface finishing requirement. The requirement here has been a primer coating in black or gray. And only for this reason, in India particularly, only these two colours are available. Outside India, where there is sufficient demand CED coating is also available in different colors.
There is a second facet to this. The epoxy based CED coatings have a high SST resistance. But they do not have UV resistance. To make it UV resistant, CED coating is used as a primer coating followed by Acrylic or PU topcoat as written by my friend Saravanan. This gives the component the best of both the worlds.
There are single coat Acrylic Ecoatings also available in colour. But again not in India. Then there are clear coat Ecoats which can be tinted. These are available in India. But for each coating or combination of coating the performance will change. You will have to evaluate what you require and the coating or combination of coatings can deliver.
Gurvin Singh
Coatec India -
Mohali, Punjab, India
Dear reader
Post an answer
Post a question
Report broken links
List of Directories
