HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 49000
Crystals on Bright Nickel Anode Bags
June 6, 2008
Currently I am having some roughness problems with the bright nickel-chrome line I work on. On Friday afternoon at the end of the working week I took the anodes bags out of the bright nickel for cleaning to eliminate that as a possible roughness source. Most of the bags have crystals growing on them, of varying sizes but are mostly diamond shaped and clear in colour. Does anyone have an idea what these could be? Are they likely to be contributing to the roughness problem? I can't wash them off. Could these possibly be calcium salts?
Also a couple of the bags had something on them that had roughly the texture of concrete, and was highly adherent to the bag, one patch was grey like concrete but the other was a coppery colour. Any suggestions as to what these might be, and how I could remove them.
Plating Shop Supervisor - Brisbane, Qld, Australia
June 12, 2008
I can think of two possibilities, hopefully others will bring in more. (1) Calcium as you suggested, but if so you would also see it as a "bunp" occlusion in the final nickel plate. (2) Most likely you have some sort of bi-polar problem where your anodes are actually negative (or "less positive") with respect to some galvanic or stray source. Get out the voltmeter and check everything.
Robert H Probert Robert H Probert Technical Services Garner, North Carolina
June 22, 2008
The crystals have been confirmed by our supplier's lab as being either calcium borosulfate or calcium metaborate.
The big job now is getting rid of them.
The good news is, we now use deionised water in the nickel solution to prevent the calcium from building up again.
June 25, 2008
John,
DI water is certainly a step in the right direction. I have also found that when adding boric acid and instant Ni carbonate (if applicable in your case), pump out 4 gallons of hot nickel solution at a time, mix small amounts of the addition well in a bucket, then when completely dissolved add it to the tank with mixing. Changing filters and anode bags regularly will help too. Hope this info. helps you.
fellow plater - Syracuse, New York
June 26, 2008
We are having real difficulty finding a way to remove the calcium metaborate, as is our supplier. Apparently the usual calcium salt that forms is calcium sulphate, which can be removed by filtering at a high temperature, but apparently calcium metaborate doesn't work that way. I can't even find any information on the solubility of calcium metaborate, regarding whether it has a 'reverse' solubility like calcium sulphate or not. Or is this something common to all calcium salts?
Any suggestions?
October 9, 2008
Hi,
We have finally solved this issue and our Ca is now just over
6ppm.
The solution was to treat at 54º with sodium bifluoride, raise pH with nickel carbonate, peroxide treat then mix in activated carbon and filter aid. Then filter to a clean tank.
After the first treatment we still had lots of Ca yet, and we found from our supplier that the bifluoride reacts not only with Ca but with Mg and silica as well, so some of our addition was being consumed by these other ions.
We did this treatment a second time, now taking all three of these ions into account and now we have a much cleaner looking nickel that is giving good plating results.
October 27, 2008
Hi, John. Thanks for the very interesting updates!
