HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 48729
My GM dealer says the peeling chrome wheels on my G6 are MY FAULT!
May 7, 2008
Hi There, I took my G6 in because 2 of the chrome wheels were peeling from the inside edge and one little place on the face of one. The service advisor said that he had the manager look at the wheels and all of them were peeling and they weren't warrantable because he THOUGHT they MAY have been cleaned with an acid that CAUSED the chrome to peel. I explained that chrome doesn't normally peel, it chips. His reply was "I've been in this business a long time and it looks like acid damage to me." I had checked Finishing.com and a couple other places (most of which didn't have nearly the info you guys have)before I went to pick up the vehicle and when I talked to the service manager I told him what I had learned on this site, that was when I got "it looks like acid damage to me" line. I told him his answer was unacceptable and I wanted to talk to the GM Rep. He said he would talk to her and he would present it to her the way HE saw it. He did, and the rep never saw the car, never gave me a chance to explain, and made her decision based on his theory. She offered to buy one wheel If I bought the other three @ $300 each(no discount). I wouldn't be so mad if the car weren't under BASIC WARRANTY, with only
32k miles and less then 2 1/2 years old. I am the second owner, however, I bought the car with 11k miles on it, looked brand new, wheels were fine, gorgeous car. I am hoping you can give me some idea of how to proceed and some more education on this.
Thank You,
Greg Elkins
Harley and G6 owner, pipefitter in an alloy plant - Huntington, West Virginia
May 8, 2008
Hi, Greg. Peeling like this is a manufacturing defect. Period. It's possible that the service manager wouldn't realize this, but the GM rep not looking at the wheels is inexcusable because she should have logged them, determined who plated them, and got to the root of the problem!
The warranty may not cover this-- there may be an exclusion for appearance items, or a shorter warranty period, or whatever. If you are sure that the wheels are warranted, you could go to small claims court. The fact that the service manager tried to blame you instead of claiming that there is no warranty bodes very well for your case.
Peeling of chrome wheels is a very widespread problem because they are so terribly difficult to plate. But they shouldn't sell them if they can't plate them correctly (or at least they shouldn't warranty them). I sympathize with the plating shop, but very soon there will be no chrome plated wheel business anyway; they'll have lost all their business to PVD processes, because companies like GM are in denial instead of investigating and giving the plating shops proper feedback.
Please tell the service manager that finishing.com eagerly awaits hearing from him what chemical can do this because thousands of plating shops spend a small fortune on expensive and often toxic nickel strippers to dissolve nickel away, and would love to know what chemical they could use to cause the nickel to just peel off instead. The environment would thank him too :-)
S |
May 9, 2008
Ted is absolutely correct. The problem is due solely to poor plating in the first place. There is nothing you have done to cause the problem. GM should be ashamed and embarrassed to have sold you such lousy plating. If they exercised proper control over their wheel supplier, it wouldn't happen.
But they won't be. They'll give you the forever runaround, then they'll invoke some fine print which they claim lets them off the hook. I think that's baloney, since there is, on their part, an obligation to supply you with plating which is up to general industry standards. The lousy plating on your wheels fails that simple requirement. Will you get satisfaction? No. GM lost interest in you the moment they had your money. Too bad, but that's the way it is. You could likely win in small claims court, but you'd need an expert witness to convince the judge. Too bad you aren't nearby, I'd be glad to testify...you see GM has nicked me too with some of their defective plating. I tried being nice, then less nice, and during my final conversation with them, they said : "TOO bad, but we really don't care."
May 9, 2008 As a chrome plater for several years, tell the guy that only some acids eat chrome and they do exactly that -They eat the chrome. The only thing that causes chrome to peel is a faulty plating job, normally in the preplate cleaning steps.
James Watts- Navarre, Florida
S |
May 12, 2008
As the others have said, what you have is a plating defect. When plating peels the problem is in the plate or under the plate, not on the surface.
Gene PackmanFrom my past experiences with GM, if you contact them directly they will make an appointment to see the vehicle and inspect the problem. If you are not satisfied with the dealer and tell them so, you do not have to go back to the selling dealer. It is important that you write to them via certified snail mail as the instructions are usually in the warranty book. Also you should point out that you will (I suggest) find others with the same problem and contact a class action attorney (they love suing GM) For the others who replied above, I have had just as many problems if not more getting Nissan and Toyota to acknowledge faults. - Great Neck, NY May 12, 2008 Don't wash the car! It will just give the dealer an "out" if the paint starts to peel off. ("Well, you shouldn't have washed it, it's you're fault and the GM rep agree's with me")
May 19, 2008
Thanks for all the responses. Sounds like GM hasn't just tried to get out of this with me. I am going to contact GM today. Wish me luck! I will keep you posted.
Thanks again,
- Huntington, West Virginia, USA
June 9, 2008
Well, I am convinced it is a conspiracy! I took the vehicle to a different dealer (as per the company rep I talked to on the phone) and got the same line about "something" causing the wheels to start peeling. General Motors has hit a new low for weaseling out of backing their product. No wonder they are losing customers. I really appreciate everyones help here and thanks to Mr. Mooney for putting my letter out there for everyone to see.
The car is developing steering and brake problems and I will probably wind up getting rid of it. Too bad, beautiful car and at 32.5 on the highway. That's hard to find in a little v6 hotrod.
Thanks again
June 9, 2008
Hi, Greg. If you can get me an e-mail address for either service manager or the GM rep I would be happy to send them an e-mail. It is possible that they just haven't seen this problem and are honestly ignorant of what causes it. But when four plating experts tell you it is a manufacturing defect, and not a murmur of dissent is heard from anyone in the world on the world's most popular metal finishing site, it's like I said from the first: a manufacturing defect, period.
June 17, 2008
Hello again, I printed the posts from here and sent them to the second dealer when my wife had to take the car back in because I couldn't get off work for the appointment. Guess what?! They didn't care either and just blew her off, too. Same answer as the other one, maybe someone had put acid on the wheels sometime. Very professional, huh?
Greg Elkins- Huntington, West Virginia
June 17, 2008
"There are none so blind as those who will not see"
June 19, 2008
I hate to say "told ya so", but the truth is GM has got your money and they don't give two hoots whether you're a satisfied customer or not.
They're busily going bankrupt.
Buy Japanese next time.
Jeffrey Holmes, CEF - Spartanburg, South Carolina |
June 20, 2008
LOL Jeff. GM should be busy doing something productive.
However, I had the same experience with Nissan.
Sheldon Taylor supply chain electronics Wake Forest, North Carolina |
June 20, 2008
Yes, we all have stories of manufacturers disavowing responsibility. What makes this one different is that it's not a disgruntled customer's personal interpretation of what is owed him.
Rather, four professionals with years of direct experience in the subject have looked at the photographs and weighed in and said with a single voice that Greg is sitting on a manufacturing defect (I'm not counting you, Sheldon, because I realize that you haven't offered an opinion on it).
Do you have a "troubleshooter" on the local TV news, Greg? Send him/her the dialog -- they'd probably like to go to a car dealer.
July 15, 2008
I guess we're looking at exposed copper, so technically it's the NICKEL that is peeling. Try to pick up a piece with a magnet. This is definitely a plating defect. Get a lawyer.
G. Brackett III- Saco, Maine
July 22, 2008
letter 44219 is on a different subject, Greg, but it concludes with something which sounds very reasonable, i.e., that you should write a letter to the dealer labeled "First Demand Letter" (or "Second Demand Letter" if you've written previously). This title makes it completely clear that you are demanding redress for this manufacturing defect, whereas without it they might claim that they thought you were just making inquiries about whether they feel it is a defect, or just debating about it.
July 23, 2008 -- appended here by editor in lieu of spawning a duplicative thread
My 2006 buick Lucern with factory wheels are chipping, the GM factory guy said it was something I washed my car with that all four wheels are chipping the plating off. The paint is fine, the chrome and other plating is fine. but the wheels are all chipping. We take are car to the same drive through and nothing is happening to the infinity wheels? Am I getting the run around? have you hear of other Lucern wheels chipping?
Diane Easonn- Lancaster, California
July 23, 2008
Hi, Diane. It isn't clear to me whether these wheels are painted or chome plated or polished aluminum, so we don't know if you have a similar situation to Greg. Send some pics please.
July 24, 2008
I am truly sorry about your trouble with a G.M. product. I will celebrate the day they finally go out of business. My experience with their products say they are nothing but cheap junk. As advised, for your future try a Japanese product, or Korean. They are still trying to build market share, and satisfy the customer. G.M. really does not care about the customer once you bought their defective junk.
- Monroe, N.J. USA
July 27, 2008
It's a manufacturing defect for sure, the respect issue(he's disrespecting you by telling you it's wheel cleaner damage) might be that you are the second owner. Auto makers are very well equipped to trace manufacturing defects back to their origin if they need to do it, but this defect is not life threatening, it's cosmetic. Back in the early '90's there was a problem that all makers had with peeling paint. The manufacturers were changing to low VOC primers and after a year, paint would peel off in big sheets from the hood and top. Ever see a fleet vehicle from that era? They all had it. My friend bought a new '93 dodge dakota and the paint peeled. The dealer agreed to pay half for a new paint job ($1000), and when it was done it looked like it was painted in someones garage. I told him if that was a $2000 paint job I'd eat my hat. He didn't fight it.
July 29, 2008
Hey Guys , sorry to take so long, I've been working some crazy amount of hours because our contract is up Aug 1st and talks aren't goin so good. I haven't done anything else yet, but I will look into sending the dealership a letter, I hope it will still fly since the car has now gone over 36k miles. I will keep you posted, Thanks again,
Greg Elkins- Huntington, West Virginia, USA
August 11, 2008
This forum has gone adrift. It is obvious the poor guy got a defective chrome wheel. But why are all the other auto manufacturers not being tied to this whipping post. I know their chrome wheels peel also. We are cheated and lied to by big business, unions, politicians, courts, insurance companies, salesmen, bureaucrats and swindlers of every stripe. Everyday! Lack of integrity is not exclusive to GM.
But that is for another forum, not "Metal Finishing".
- St. Louis, Missouri, USA
August , 2008
Hi, Frank. I agree with you that this posting should not be about GM-bashing and I apologize for my part in that. Actually, bashing reduces Greg's likelihood of getting satisfaction.
GM is the subject of this thread because the car and wheels pictured are GM, and they illustrate a manufacturing defect which is interesting to both the public and industry professionals. The manufacturer is refusing to acknowledge the defect and that naturally attracts people to chime in with "Me too!".
Ford and Subaru are the subject of metal finishing complaints in letter 44219, BMW in 29693, Harley Davidson in 30196, and so it goes.
September 9, 2008
Went to Capital Buick yesterday with 4 peeling chrome wheels.
They looked at them and blamed it on road salt.
The car is still under warranty so they called GM who wanted photos.
Took the car back today and they took photos and said GM is going to repair or replace the wheels whichever is cheaper.
To repair the wheels they have to be sent to California and I would be provided a rental car for 6 weeks.
The dealer thinks GM is going to replace the wheels.
I can't believe how accommodating they have been so far.
I'm crossing everything I have in the hopes that they keep it up.
- Atlanta, GA, USA
