48716
Grit blasting SA 2.5 [Iraq]
May 6, 2008
I HAVE AN INQUIRY FOR GRIT BLASTING SA 2.5 WHAT IS THE TECHNIQUE
AND MATERIALS USED FOR SUCH METHOD? AND THANKS FOR ANY SUGGESTION.
BASHAR THABIT
CONTRACTING COMPANY ENGINEERING DEPARTMENT - BAGHDAD, RESAFA
May 9, 2008
You need a mid-size compressor (90-100 PSI, 10-60 HP depending on
area to be blasted), suitable hoses, pressurized reservoir with
opening to load blasting media and discharge pipe outlet, angular
(fractured) steel shot, nozzle 3/8"-1/2" of inside diameter (ceramic
or tungsten carbide preferred but hardened steel also possible),
operator (either in cabinet with gloves or covered with rubber or
rawhide apron and gloves and suitable face shield). Look for shot
blasting equipment in your preferred search engine for pictures of
system.
Guillermo Marrufo
Monterrey, NL, Mexico
