(Cycles thru suppliers)
  48694
How to achieve polished finish #7 on 316L stainless sheet? [China]
May 5, 2008
I got a request for the material plate 316L stainless steel part to be stamped and polished to a finish grade of polish #7. As I know it almost looks like mirror or so called mirror finish. However I would like to know how to achieve that and by what equipment if I start off from a sheet metal of 0.4mm 316L stainless steel BA finish?thanks a lot!
Brian Lam
metal stamping manufacturer - Hong Kong, China SAR
May 16, 2008
Are you sure your material is .4mm thick? If so, you can not reprocess it.
AF Kenton
Nova Finishing Systems Inc.
Huntingdon Valley, PA
