48636
Compatability of Plastic, Resin and Rodine [Brazil]
April 29, 2008
We are thinking to prepare a acid solution in a truck (used to transport HCL) with HCL and and inhibitor Rodine. I would like to know if rodine can affect the internal covering made of Plastic+fiberglass and resin Derakeni (CatBO411).
Roberto Villarroel
Chemical Eng. - LA /Brazil
May 12, 2008
Please define rodine. What is it?
Guillermo Marrufo
Monterrey, NL, Mexico
June 11, 2008
Hello,
I don't know why are adding RODINE (see note) to the HCL if your Truck Tank is already coated with plastic.
Rodine should be used for parts being inmersed into HCL solution.
Other way, RODINE wouldn't attack (in the case) your Resin (alcohol is about 12% diluted.
Jose Castellanos
NOTE
RODINE => http://www.telfordindustries.com.au/Uploads/Images/Rodine%20213.pdf
Jose Castellanos
- Minneapolis, MN, USA
