48610
Need corrosion resistant agent against
heated inconel [Japan]
April 22, 2008
Our workshop operates wear-resistant coating for metal and plastic
item. One of our customers asked us if we can give this coating on an
inconel plate, which is heated at 760 degrees celsius for continuous
100 hours. Normally we carry out coating under the temperature of 250
degrees.
We put an inconel plate into the furnace and gave heat treatment at
760 degrees for 4 days. After taking it out, we checked the plate
under a microscope and found small dots of rust on the surface. The
customer has approved the coating but he was not happy about the
rust. Now he is asking us to get rid of this rust. It must have been
generated under this extraordinary setting. We wonder if there is any
solution to this problem.
Kazuhiko Kawashima
Plating shop - Osaka, Osaka, Japan
June 11, 2008
Deasr KAZU,
Rust is taking place onto the bare inconel surface; i.e. that your
coating is pourous (typically). So, use, first, a bonding coating to
protect the Inconel from this degenerative process. One more
suggestion: incease furnace temperature to melt totally the coating
powder. Period.
Jose Castellanos
Jose Castellanos
- Minneapolis, MN, USA
