48609
Parameters for anodic etching
[England]
April 24, 2008
Can anyone suggest a common set of parameters for anodic etching
of steel parts.
We use a 35-40% solution of Sulphuric acid, connect the parts to the
anode and set 20 ASF for 5 minutes. Then 200 ASF for 1 minute,
followed by a cathodic etch at 200 ASF for 3-4 seconds.
Is this similar to what others are doing, and is the cathodic etch
necessary, and if so, why?
Michael Channing
Senior Chemist - Hampshire, England
April 29, 2008
Mike,
Have a lookat DEF STAN 03-2, it describes various anodic and cathodic
etches, their usees and restrictions. If nothing else it will give
you a starting point. You could also have a look at MIL-S-5002, the
US equivalent spec.
Brian Terry
