Banner at right -->
cycles thru
India-based suppliers
  48530
Zinc phosphating - Process flow, requirements and specification [India]
April 16, 2008
Hi,
I am Ramanathan,
I am working in vendor development (auto industries)
Here I am looking in surface finishing process, Little bit I know about plating and anodizing process because I handeled these suppliers.
In future I will develop zinc phosphating process also.
So kindly consider above mentioned queries and send back to positive feed back
Thanx
Ramanathan Nathan
buyer - Chennai
April 18, 2008
Hi, Ramanathan. Two great references for this would be Samuel Spring's "Preparation of Metals for Painting " and "Phosphating of Metals" by Rausch & Rausch. Good luck.
finishing.com
Brick, NJ
April 22, 2008 -- appended here by editor in lieu of spawning a duplicative thread
We face rusy problem during zinc phosphating of Bearing races
Can someone help
Aman Bhargava
Engineer - Jaipur, Rajasthan, India
April 22, 2008
Hi, Aman. Please see the previously mentioned books for a general intro to phosphatizing issues and problems. Our readers have helped on 50,000 threads so far and I'm confident they can help you with your problems, but you have to give them some informaton to work with.
finishing.com
Brick, NJ
April 23, 2008
No home brew will do as well as a proprietary solution from an established reputable vendor.
Normal cause is the part is not cleaned properly. Grit blast is a preferred method with a quick caustic cleaning to remove trace oils and then processed thru the phosphate.
If you are using an acid dip, then you need an additive in the rinse before the phosphate AND it needs to move with all due haste because it will flash rust after the acid, even in the rinse tank.
- FL
