48479
Compatibility of stainless steel with zinc
nickel plating [Canada]
April 10, 2008
I have a rivet with zinc nickel plating, and spring with stainless
steel material.
If these two components are attached together, will there be any free
electron between the two, and have red rust faster ?
Fred Lajewardi
engineering - Canada
April 11, 2008
Hi, Fred. Galvanic corrosion is always an issue when
different materials are connected together. The severity depends on
the exposure (if it's dry, little problem; if it's wet, serious
problem; if it's salty and wet, major problem); the potential
difference between the metals (zinc nickel plating is a sacrifical
plating and thus quite active); and the relative sizes (a small
active component connected to a larger less active component is
trouble). Unless this is a well protected component, indoors, in an
electronics device, it sounds like trouble to me.
finishing.com
Brick, New Jersey
April 11, 2008
Ted is absolutely right. If you want to minimise the risk of
corrosion, use parts made form similar metals, or put an insulator
(eg plastic gasket or washer) between them. This will minimise the
chance of any galvanic couple forming.
R&D practical scientist - UK
