48469
Blade corrosion when the aluminum spacer
between two blades(stainless steel ) [China]
April 9, 2008
In the common sense, when the aluminum touching with stainless
steel, the aluminum will first corrosion....'cause it's more active.
but in our case is just different, which the steel is first
corrosion....y?? it's quite abnormal. if the plastic spacer between
two blade the corrosion will be much better! so I do believe issue is
on the aluminum spacer....pls expert tell me y? and how to prevent?
actually whether we pickling or not. this issue is always happen.
Jason Yang
engineer - China
First of two simultaneous responses -- April 10, 2008
Nihao Jason,
What is the corrosion agent or substance? Aluminum is very resistant
to oxidizing environments like nitric and chromic acid. It is not
resistant to reducing agents like chlorides, fluorides and alkalies.
If anodized it becomes non conductor.
Zai jian!
Hanyu Xueseng
Guillermo Marrufo-Monterrey, Mexico
Guillermo Marrufo
Monterrey, NL, Mexico
Second of two simultaneous responses -- April 10, 2008
You have a galvanic couple betwen tyhe aluminium and the stainless
steel, but in reality, the aluminium is covered in aluminium oxide,
which has a higher redox potential. Corrosion then occurs on the
stainless steel because the other electrode reaction is more
electropostive. Hwnce, the electrode potential of the aluminium oxide
reaction is more cathodic than that for stainless steel, so it is the
steel that corrodes. Inserting a plastic space between the steel and
the aluminium breaks the circuits, so you do not have a galvanic
couple between the two metals and therefore no electrochemically
induced corrosion
R&D practical scientist - UK
