48467
Silane primer or phosphating as an alternative to grit blasting? [Korea]
April 10, 2008
Hello I'm working in shipyard.
I wonder if silane primer is applicable to carbon steel or welding joint as an alternative grit blasting. Is it more expensive? Does it need complex process?
Also phosphating carbon steel needs temperature control?
Your answers will be very appreciated.
Lee Cyria
shipbuilding - Korea
April 30, 2008
Hi, Lee,
Applying primer on welding area is a sealing process to reduce rust speed; however the scale will rust and pop up. So, the welding scale needs to be removed by either physical or chemical way. Contact me if you want to know chemical way.
Yes, you need to control the temperature for phosphate process.
Jun Zhang
- Cincinnati, Ohio
May 3, 2008
WE OFFER, UNDER OUR BRAND NAME: ZINPOFOR, ZINC PHOSPHATING CHEMICAL, WHICH FUNCTIONS AT A25+ DEG. C, AND GIVES ZINC PHOSPHATE COASTING, COATING WT. RANGE: 300 TO 500 MG. SFT. PLEASE FEEL FREE TO ASK FOR ANY MORE INFORMATION YOU MAY NEED IN THIS CONNECTION. REGARDS.
S. MEENAKSHISUNDARAM
Guardian Anti-Corrosives Private Ltd.
CHENNAI, TAMIL NADU, INDIA
