48436
Metal on Metal - Zinc Phosphate
[Arkansas]
April 5, 2008
We fabricate steel products and many times we have steel laying
across steel. Our competitors use no kind of protection between the
metals, they simply paint the finished product. subsequently rust
will form and begin to bleed out. Would a zinc phosphate coating on
both metals prevent rust forming in between the metals?
Steve Ashmore
Fabrication shop - Rogers, Arkansas, USA
April 8, 2008
Hi, Steve. Zinc phosphatizing is considered a quality pretreatment
method for steel components. If you or your competitors are doing
something less in terms of pretreatment, then zinc phosphatizing will
certainly improve your product
The ideal treatment, but the most expensive, is zinc plating and
chromating (or galvanizing), subsequently phosphatized, subsequently
electrocoated, subsequently powder coated.
The least effective treatment is solvent wiping followed by
painting. The first step up would be phosphatizing followed by
painting -- but whether it is good enough to solve your perceived
problem is hard to say.
finishing.com
Brick, New Jersey
April 30, 2008
Hi, Steve,
Selection and quality of pretreatment is tightly related including
type of paint. It sounds you may need to review both yours and your
competitors'¯ process to need your customer¡¯s need.
Jun Zhang
- Cincinnati, Ohio
