48391
Compatibility of aluminum and galvanized
steel [Philippines]
April 3, 2008
I would like to ask if I still need a nylon separator between hot
galvanized steel and aluminum surface where there is a direct contact
between the two? where in fact there is a expected water running
through it.
I am reviewing a desing drawing with the above condition. this is for
the facade shop drawing. please help.
Mai Saxor
engineer - Philippines
June 4, 2008
Mai
I'm an architect and asking a similar question here in UAE of
anodized aluminium supported on galvanised steel frame. Here it's hot
and often dry heat but summer creates high humidity and the site is
right on the Arabian Gulf.
I think a nylon separator is necessary but the question may be a
bigger one than only contact. I understand that rain water can
connect the two metals and still produce corrosion.
Can anyone confirm or refute this? Should I be using powdercoating
instead of galvanising?
Matt Brindley
Matt Brindley
architects - Al Raha, Abu Dhabi, UAE
June 4, 2008
Hi, Matt. Galvanic corrosion is not the only kind of corrosion, so
avoiding galvanic corrosion doesn't guarantee that a material will
last indefinitely in an exposure condition, but it certainly helps.
You will not get galvanic corrosion if the parts are not
metallically connected. That's my understanding anyway.
A galvanic corrosion cell works like a battery connected to a
lightbulb. Two different metals like in the battery, salty conductive
water or moisture like the conductive glop in the battery, and a
metallic connection like the wires and light bulb. A battery may last
only a short time powering the light bulb, as metal moves from anode
to cathode to produce the power; but the battery will last a long
time on a shelf because the metal cannot move from anode to cathode
without the wiring.
Positively charged metal ions can travel though watery solutions
but electrons don't. Metal can't electrochemically move from one
place to another without a path for the positively charged ions
(moisture) and a path for the electrons (metallic connection).
finishing.com
Brick, NJ
